ecu testing
ecu testing
hi im wanting my ecu testing,no spark. ive herd of a place in holland that tests and repairs them does any1 know there name as i cant find much info on them . any info i would be greatfull
Re: ecu testing
http://www.carmo.nl/index.php?language=en
as far as I know no one has actually sent anything to them but someone has been in email contact with them.
Re: ecu testing
thanks.. leisure trail told me about them today said 1 of there customers used them . i just couldnt remember there name
Re: ecu testing
contacted them this was there reply ==== .... We still can´t simulate the CRM250 MK2 unit, because nobody has a workplacemanual for that motorbike.If you have a workplace manual from that bike you can send the unit andregulator to us, but without a workplace manual we can´t help you.You are the 5th person with a CRM250 MK2 than wants his unit tested/repairedthis year. The other 4 did not have a manual... Best regards,Robert DraaijerTeam
- Bike Owned: crm mk2
Re: ecu testing
I think unless anybody comes up with an alternative there wil be a lot more bikes broken for spares,.ive just modifeid my mk 2 to a mk1 ecu, but i woulndt recommend it, its down on power and not an easy task, as much as i want to stay loyal to the bike it is a major concern as i ride some very remote areras and thay are failing all the time it seems ,
- woolley
- Bike Owned: AR
Re: ecu testing
[quote="wheelright"]I think unless anybody comes up with an alternative there wil be a lot more bikes broken for spares,.ive just modifeid my mk 2 to a mk1 ecu, but i woulndt recommend it, its down on power and not an easy task, as much as i want to stay loyal to the bike it is a major concern as i ride some very remote areras and thay are failing all the time it seems ,[/quote]
Where is Chon Buri
Where is Chon Buri
Re: ecu testing
you have internet access to get on the forum but not to do a google search???
....Thailand
....Thailand
Re: ecu testing
easyrider wrote:contacted them this was there reply ==== .... We still can´t simulate the CRM250 MK2 unit, because nobody has a workplacemanual for that motorbike.If you have a workplace manual from that bike you can send the unit andregulator to us, but without a workplace manual we can´t help you.You are the 5th person with a CRM250 MK2 than wants his unit tested/repairedthis year. The other 4 did not have a manual... Best regards,Robert DraaijerTeam
I take the manual TITE put up won't do, I haven't looked to see what was in it, just a thought as I may be needing another mk2 cdi soon fingers crossed
Re: ecu testing
I've just looked at their site. They say they have tested and repaired Mk1 & Mk2 ECUs (and quote the numbers on the ECUs).
Stupid question but - Do you think a Japanese version of the service manual would be enough
. Are they only looking for the purposes of the pins/what they connect to
Came across someone in the US who needs 30 Mk2 ECUs and one in Trinidad & Tobago who needs one.
Re: ecu testing
The further I look into this the more desparate the plight seems. There people literally all over the world looking for Mk2 ECUs
Someone in the Philipines seems to have got his repaired by chipping out the sealant and getting the duff component replaced by an electrician. But no detail and I can't work out how to contact the people involved (+ it's a translation (but a good one)).
Re: ecu testing
ive got another ecu to try,and just had the loom n handle bar switch's off l3on deliverd today, ill fit it when my new rectifier comes let u know
