help please
help please
brought my mk2 as a non runner, its got no spark its has no igniton switch,kill switch,what wires need to go where ?? was used off road.i taken a gamble n tryed diffrent parts cdi,stator pick ups, i put 12volts straight to the wires from the rectifier[good bad idea???], red an another cant remember now. every thing seamed to be live but still no spark when kicked over, any help or advice id be very greatfull ....about to give up and break it n ebay it,, witch i dont wanna do
Re: help please
Sorry. Please don't think I am being unhelpful but without seeing the bike I can't rewire it for you.
Are you sure you have checked the basics - spark plug, ignition coil, generator etc then the wiring connections and the circuits and resistances. There is a wiring diagram in the CRM guide done by Leisure Trail. You should be able to work out the loom from that.
- Gammakeith
Re: help please
The only trouble with the Leisure Trail manual is that there is no colours marked on it (or at least in my AR version)! I spent ages repairing my wiring and mine hadn't been hacked about too much. If yours has been butchered then bank on spending a fair while sorting it out. As stated below you just need to methodically sort through the wiring. There are not too many wires that are needed for it to spark!
Keith
Keith
- Active Rascal
- Forum Ghost
- Bike Owned: CRM 250 AR
Re: help please
Have you ensured the sidestand switch is correctly bridged over, as I believe this is part of the ignition system, corrections welcome!!
Re: help please
hi no it aint got a sidestand and i cant find any switches that side of the bike only wires that are loose are two 1 light green and 1 dark i think , can i post pics for you s to have a laugh at or at best give some guidence
Re: help please
There is a description on the site about shorting out the sidestand switch on the forum but I can't find it
. The connection is the green connector that sits under the front of the seat. Two of these wires need to be connected together but it only shorts the ignition out if the bike is in gear.
Re: help please
I have to say, take it in to a good shop that have a true understanding of bike wiring.
My CRM had alsorts of issues when I put it back together
Just a simple issue ,there are two plugs behind the headlight that are the same fit--I put them around the wrong way
The shop striped back the outer and fixed
If the guys on here cannot create tips to fix - mainly because they cannot see the issue, maybe the shop can.
Dont give up
I just love my angry wasp with all its mad tendencies.
I am sure that that somone on here can recomend a place to take the bike close to were you are.
Good luck
Dont give up
Good luck
Re: help please
cheers, im in nuneaton if anyone nows of any where to take it
- Gammakeith
Re: help please
I've never used the guy but 'Ferret' has got a good reputation in the Vintage jap crowd and he'll come out to you. He shouldn't be troubled too much as the CRM uses standard connectors etc.
http://www.motorcyclewiring.co.uk/
Keith
Keith
