2st oil system
- leecoulson
2st oil system
hello ,
Is it possible to remove the auto lube system ( i think thats what its called)
when i pour my 2st oil in it doesnt tell me the level at what the oils at,
so i just mix it in with my petrol.
Re: 2st oil system
the auto lube system can be done away with ,but there should be a sight tube on the rhs of the frame to show the level if your not getting a reading on it it looks like theres a blockage in the pipe ,take it off and have a check round
Re: 2st oil system
Don't forget that adding oil to the petrol means you will most likely need to rejet too.
- leecoulson
Re: 2st oil system
cheers, how can i take it out/off?
Re: 2st oil system
by searching the site....
Re: 2st oil system
Roughly, every third fill of the fuel tank.
It's also a prescriptive dosage, thus, only adding the oil required [ once set accurately]for any given R.P.M., so less coking up of internal workings. I.M.O.
