crm kick start slipping
shane
Post by shane »
hi
i brought my crm 250 mrk 2 just over a week ago and have nothing but trouble with it. the bike wont start from cold when using the kick start but eventually starts when bump starting it but when warm its fine and it runs like a dream, the kick start slips when you kick it to hard so took it to bits and everything looks fine and not worn does any body no what would be making it slip? also where i can get the parts from as i have lost one of the springs lol and have tried every were for one
any advise would be a great help.
Re: crm kick start slipping
A friend of mine had a CRM that did exactly the same thing. We took the kickstart out, checked it, cleaned it, lubed it, though it looked clean and well lubed with no apparently worn parts. When we put it back it was only slightly better.
Experience says replace the whole kickstart unit though I haven't been able to find out what is going wrong.
Others :?: .
Post by twistednuts »
The cold start syndrome seems to be a common problem. Give carb a good clean, new plug and check cap.
Rollin the bike back and forth in gear helps. So does lying the bike flat till petrol pees out of the overflow. The latter works for mine when its been stood a while
mr_bump_12
Bike Owned: Mk1
Post by mr_bump_12 »
Parts = look at.. LT(below) or a Honda shop. (Have a little look in FAQ - viewforum.php?f=20)
http://www.leisuretrail.co.uk/Home.htm
Best of luck, Mikey.
Bike Owned: KTM 200 exc
Post by back off road »
what are the rings like ? , i had the same problem with my first Mk2 it got progressively worse ,when i got it a couple of kicks and it was running then a few more, then no matter how many kicks it wouldnt start ,once i gave it a good dose of looking at and checking i found the rings were very worn ,a new set in and away it went first or second kick everytime
shane
Post by shane »
hi
thanks for the replys, i have been told by a friend that if i grind the teeth on the kick start and replace the springs then that should work lol and apparently the bloke i brought it of said he had recently changed the piston him self so rings should be ok and it seems to have loads of compression, think i need to spend a whole day looking at it,
shane
Post by shane »
Hi fixed problem spent 130 quid on kick start bits from lesure trail and kick start works perfect now
and as for the not starting when cold someone told me to kick start it with no throtle and chock on and it satrts arfter about 3 kicks now also helps the fact I can give it a good kick now with out worrying I'm gonna hurt my foot when it slips lol
