Crm250 AR Servo (wire colors)
2TRacelab
Post by 2TRacelab »
Hi.
Can someone help me out with the colors of the wires that come out of the servo mechanism?
I believe colors should be:
1)Pink
2)White-Black
3)White-Green
4)Red-White
5)Blue
Is it possible for someone to have a look?
Though a schematic with wiring colors would me more helpful... :roll:
Active Rascal
Forum Ghost
Forum Ghost
Bike Owned: CRM 250 AR
Re: Crm250 AR Servo (wire colors)
Post by Active Rascal »
Hi,
Assuming you mean the powervalve servo motor unit, they are as follows:
WHITE
BLACK AND WHITE
LIGHT GREEN
DARK GREEN AND BLUE STRIPED
RED AND WHITE STRIPED
BLACK AND WHITE STRIPED
I cannot tell you where they go on the bike as my bike is not at home, and to find which components within the servo they go to would require taking it apart, dont really want to do that as the gears can fall out and a bit of a git to get back.
Hopefully I've helped you.
Active Rascal
Forum Ghost
Forum Ghost
Sorry, You can see by just splitting the thing and not the tiny gearbox.
To motor:
WHITE
To potentiometer:
LIGHT GREEN
All of the above feed into/from ECU and Throttle Position Sensor, cannot tell you which colours without my bike.
PS, sorry i listed black and white twice in previous post.
Active Rascal
Forum Ghost
Forum Ghost
In addition to this, you are correct with the colours on the wiring loom, sorry didn't realise you meant that end.
2TRacelab
Post by 2TRacelab »
Thank you very much for the help.
Do you mean that the wires change color at the servo mechanism fitment?
Active Rascal
Forum Ghost
Forum Ghost
They do... I understand all servo motors across the models are the same, however wiring looms are different which may expkain this. If you need any more help i can get the multimeter out over the weekend? I 'nearly created a colour wiring diagram once but soon decided against it.
2TRacelab
Post by 2TRacelab »
So, the colors that I mentioned are from the servo motor and the ones you mentioned are for the wiring loom?
