fuel consumption ?
buggsywabbit
fuel consumption ?
Post by buggsywabbit »
hi there fellow crm owners ! question :- i have a crm 250 mk 2.2 , and can anyone tell me the range in miles on a full tank ? so as i can determin the condition the tuning and condition of the machine ! i look foreward to your reply/s g.....
Active Rascal
Forum Ghost
Forum Ghost
Bike Owned: CRM 250 AR
Re: fuel consumption ?
Post by Active Rascal »
I couldn't tell you, but bit of a vague question, lots of variables to be thrown in there. I couldn't even hazard a ball park figure, but I'm sure someone can on here.....
Active Rascal wrote:I couldn't tell you, but bit of a vague question, lots of variables to be thrown in there. I couldn't even hazard a ball park figure, but I'm sure someone can on here.....
+1, I can get nearly 90 miles before reserve is needed, others on smaller gearing get a lot less, but you might as well have asked how long is this piece of string in my pocket, due to variables as alluded to above.
Post by twistednuts »
Ive never understood that sayin 'how long is a piece of string'.
Half its length x 2 etc.
Why have you got string in your sky Mike? :?
In String Theory every string must be close to a Planck length, which is about 10 to the minus 33 centimeters, or about a millionth of a billionth of a billionth of a billionth of a centimeter.
In order to include closed loops as opposed to open ended strings, there must be a special kind of symmetry called supersymmetry, which means for every boson (particle that transmits a force) there is a corresponding fermion (particle that makes up matter). So supersymmetry relates the particles that transmit forces to the particles that make up matter.
Hope that helps.
Ahhh, i was a little bamboozled, but youve cleared things up.
pudzie83
Bike Owned: mk2 1992
Post by pudzie83 »
not alot if your throttle happy :)
I was alluding to the superstring theory, as opposed to higs bosun normal theory.
And, if I want to keep superstring in my pocket, that's between me and my underpants ;) .
fishtail
Bike Owned: CRM 250 Mk3
Post by fishtail »
i'm on my 4th pint and I only walked to the loo and back........ :D hows that for mileage? :lol:
( my mk3 does a bit better 130 km ish on standard gearing... altho the jets were massive! 152 an 60 pilot then )
now on 15 f 48 R - with standard jets it does anywhere from 70 to 90 km allegedly - accuracy is dubious since I cracked the speedo and my reserve dont work hence extreme anxiety if I get to 60 on the odious odometer
and if mike's string gets ravelled around the rear it can really bring the resistance up :shock:
ok I better go to bed now!
