Time to clean the spares
helisupp
Bike Owned: CRM AR (4)
Post by helisupp »
Rather than leave spare carbs gathering dust its time for a refurb and ultrasonic clean before wrapping up for stock.
Before we start:
pudzie83
Bike Owned: mk2 1992
Re: Time to clean the spares
Post by pudzie83 »
does ultra sonic cleaning make more difference in power/delivery? always room for improvement :)
helisupp
Post by helisupp »
If you had no power due to blocked jets...yes.
Otherwise....no
helisupp
Post by helisupp »
1st carb.........
Had wrong needle
Broken idle jet
Wrong main jet with funny homemade spacer
Slide back to front, YES BACK TO FRONT.
Carb now just being used for spares for other 2.
And some people wonder when they buy an old CRM why it runs rough.
bmvin
Post by bmvin »
Just finished building a mk 2 bought as a non runner due to a carb problem, give it a squirt of easy start and bingo it ran at least whilst squirting the can.
Ordered new jets a needle and gasket kit from LT took the carb off for a dig out to find new jets and an immaculate carb without a trace of petrol in it? Petrol pipe into a jam jar no problem there, blow down the petrol inlet on the carb no problem there. The float however was hung down like a cow overdue milking, put the float bowl on and the float valve was being pushed into the closed position. Presumably a previous owners attempt at setting the float height without establishing where the datum points were. Two mins with the pointy nose pliers problem solved,
helisupp
Post by helisupp »
Always best to dismantle and check condition of parts before you order anything.
