Ebay BeWarey
Re: Ebay BeWarey
Not original 'dog bones' - http://www.ebay.co.uk/itm/Honda-CRM-250 ... 233d7558a8
And for some reason has an exhaust bracket bolted on to the linkage?
Re: Ebay BeWarey
AR ECU. http://www.ebay.co.uk/itm/Honda-CRM-250 ... 4adc438ee1
Says - Not sure if it works but he had the bike running before he split it - So what has changed? Or did the bike run but the power valve didn't? Shows picture of a very nice AR which I assume is the bike before splitting.
Why strip such a nice bike if the ECU works? (or even if it doesn't) AND Why say untested as 'ran before it was split'?
Re: Ebay BeWarey
I think Leisure Trail have a draw full of similar items, how much do they charge for them?
- pudzie83
- Bike Owned: mk2 1992
Re: Ebay BeWarey
WOW deal of the year
http://www.ebay.co.uk/itm/Honda-CRM250R ... 1355348716
Re: Ebay BeWarey
Listed as Mk1 crank cases but are not. Can't tell what they are from but not Mk1. Also partially removed engine number doesn't help! - http://www.ebay.co.uk/itm/honda-crm-250 ... 51cbaec96c
Re: Ebay BeWarey
http://www.ebay.co.uk/itm/Honda-CRM250- ... SwY3RXJKtS
Mk1 engine will fit into any other mk frame BUT WILL NOT RUN unless you change the wiring loom and ECU to suit. VERY difficult job unless you swap everything over.
