Front fork question
- frostoff
- Bike Owned: CRm250AR
Front fork question
I am doing a seal replacement on my forks and looking at the manual there is a special tool
(front fork spacer 07KMZ-KZ30101) can anyone tell me the dimensions of said spacer ie thickness.
Cheers frostoff
Cheers frostoff
- 2016NWAA
Re: Front fork question
I can't think what they mean, can you copy a picture of it and what is it meant to do?
amazing what you can find on the internet!
http://pmoctopus.exblog.jp/26191825/
Never seen or used one. Why is it needed?
- 2016NWAA
Well you can't get a more detailed answer than that.gregorious77 wrote:amazing what you can find on the internet!
Might be able to get one made if you need it?
Surely it's just a driving dolly for the seals ?
- frostoff
cheers guys apparently you need one when topping up the oil.
- Attachments
- Picture a
- 190704.jpg (124.01 KiB) Viewed 12202 times
Typical Honda over engineering things. Its 2mm ffs. Who is measuring their fork oil level to that sort of accuracy in the first place. Also it sits against the dust seal which is rubber not a solid stop.
