Engine cuts out when put in gear
- Bultacobob
So a Mk3 been stood a while but now starts well and revs freely. Clutch disengages but a bit sticky. So when putting it into gear the engine cuts out even when revving the nuts. It like a switch, I don't think that it is the clutch sticking. Any insights or solutions much appreciated.
Re: Engine cuts out when put in gear
Sounds like the side stand switch is faulty. Its quite easy to bypass, not sure if they are still available.
https://www.cmsnl.com/honda-crm250r-199 ... 700kae305/
As above
- Gammakeith
The side stand switches are fairly standard accross Hondas from that era. I bought a second hand one off a Honda four of some description. It worked fine though I needed to solder on the lead from the old switch as the connectors were different.
Keith
Keith
