Reed stop
Reed stop
I read another post a while back from a fella saying that his
reeds dident have a reed stop plate and it was agreed that this wasent
unusual for two stage reeds. So, I removed the stopper from my active reeds
and am now having second thoughts since my barrel is at the cleaners
and am soon to have a new top end I wouldent want them snapping on me.
Usually the reeds I've seen without stops tend to have a thin metal re-enforcing plate at the screw holes and since there isent one
on the active reeds - Ive just screwed right into the existing
holes I'm paranoid that they are gonna tear off? Need I be worried?
- 2016NWAA
Scrubs, are you are having the cylinder rebored?
If so make sure that you check that the piston will clear the power valve.
I've just been refitting the cylinder on mine after a 1.5mm rebore. Luckily I checked that the piston would miss the valve.
Did a search on here and found that the usual practice is to file the valve
until there is clearance. Jobs now done and the engine is back in the frame.
I'm going on a First Biker on the Scene First Aid course tomorrow but just might get time to finish the job at night.
Good Luck
Good Luck
- 2016NWAA
Did you send the valve with the barrel? I think they asked for it to be included when I enquired about a tune.
I decided not to go for the tune as to be honest all I want now is the ******g thing to go and I really don't care how fast.
Even if you have sent the valve it is worth asking if he has checked the clearance as they only do work that you ask them to and have quoted for.
It was quiet an honor for me to speak to Stan Stephens, legendary LC tuner. 8)
[b]Eddie Evans :[/b]
I know exactly what you mean mate I think mines been off the
road for around 7 weeks now and I am bored shitless commuting
on my four stroke.
I just hope the bitch fires up when I get it all back together
and not having to still chase electrical faults.
on my four stroke.
[quote]I read another post a while back from a fella saying that his
holes I'm paranoid that they are gonna tear off? Need I be worried?[/quote]
Think that may have been me who posted that,i brought some aktive reeds and upon fitting them there wasnt a reed stop fitted
mine does have that thin metal plate tho,Havent got the bike running yet tho(been decorating the last few weeks havnt had time
)may still buy one before running yet tho if i see a cheap one on ebay but as been said before some dont have them so im not to worried.
