flywheel
baker21
flywheel
Post by baker21 »
had the cover off the flywheel just checking all was still tight,the nut was tight but i could feel some up/down side to side movement in the flywheel,not much just wondering if this is normal :o also it was the same with the balance shaft but i could see the movement in the balance shaft :o is this normal or do i need to whip the box out and start replacing bearings(the bearings i should have replaced at the start when the box was off the bike :roll: :evil: help please :)
Re: flywheel
I agree - it looks very much like you have some bearings to replace :cry: There really should not be any play in the things you have mentioned.
baker21
Re: flywheel
Post by baker21 »
as i was building it up i knew i should have changed them but they seemed ok :? never mind will just have to whip the box out and replace them,shouldnt take to long :roll: :lol:
