Am I missing something
Hi All,
Did the obligatory front bearings last night on my Mk.2/2.
Noticed the only one that was knackered was the brake disc side, changed both though.
Anyhoo, got me thinking, I've seen other Mk.2's that have a flat disc cover inside the front brake discs carrier (Mine doesn't have one), does anyone know what I mean, and whether this would afford the bearing on that side some protection from the elements, is that what it's there for? The bearing on that side does seem very exposed on mine.
Maybe a part number?
Cheers!
Cheers!
http://www.ddgraphics.co.uk
Treat yourself!
Treat yourself!
Re: Am I missing something
do you mean the black clip in disc centre?,i ripped the one off mine as the hub kept getting full of crap that couldn't be cleaned easily
Yep, that sounds like it......
Treat yourself!
Treat yourself!
Is this it
I have done as Slider.
If this is the part you need in the photo, the part no is 44610kw3010zb - Lings Honda show one in stock for £6.20.
pmac.
pmac.
If you need it I can post you the one in the photo. No cost.
knackeredMk1 wrote:If you need it I can post you the one in the photo. No cost.
Generous offer and thank you, but after meeting up with some mates with CRM's that have this part fitted, they seem to go through just as many, if not more, front wheel bearings as I do!!
Very much appreciate the offer though.
Cheers!
Treat yourself!
Treat yourself!
