mk3 ar clutch rattle?
minty0_10
Post by minty0_10 »
evening all, while out on the bike at the weekend ive had a clutch rattle start only rattles when the lever is pulled in at first it sounded like when you use a horn or a indicator with a flat battery if that makes any sense. :?
ive not taken the clutch cover off yet is it a straight forward job or is there anything i should be aware.
are there any coman faults that could be causing it?
