15 tooth front sprocket
chris356
Post by chris356 »
has anyone ever fitted 15 tooth front sprocket,seems a cheaper option than buying a 42 rear sprocket,running 17" cagiva wheels
f0xxee
Re: 15 tooth front sprocket
Post by f0xxee »
Hi there,
yes I did last week, but ended up returning to a 14 tooth sprocket.
The problem is the clearance between the engine casing and the steel chain guard that fits inside the plastic external guard. Both need to be modified to fit. Not a biggie, but has to be done.
Cheers,
Foxxee
chris356
Post by chris356 »
thanks foxee i will get a new rear sprocket instead i wont have to mess about changing the front every time i change to cagiva wheels. a big favour from you foxee, gary glitter can you kick him in the nuts & hang him from a tree we dont want him back over.thanks again for info
chris356 wrote:thanks foxee i will get a new rear sprocket instead i wont have to mess about changing the front every time i change to cagiva wheels. a big favour from you foxee, gary glitter can you kick him in the nuts & hang him from a tree we dont want him back over.thanks again for info
:D Can i take it you don't want to be "in his gang " :lol: :lol:
chris356
Post by chris356 »
he faces a £5000 bounty from gangland chiefs & when he gats back to uk we will end up paying for his protection which will run into tens of thousands & he ends up with thousands selling his story give me a gun or even a spade & i would willingly take his head off.no dont want to be in his gang
