A/R VACUUM SWITCHES
A/R VACUUM SWITCHES
This switch seems to control a vacuum pull rod that in turn raises and lowers the throttle stop.
Close inspection of it in operation with the engine running seems to show that it should , through the push / pull ,rod keep the throttle stop lever pulled up tight against the idle screw , [ i think ] .
What appears to be happening is that the switch is cutting in and out , this in turn then sets the engine into a increasing and decreasing RPM cycle , that by holding the plate against the idle screw end , you can reset for a short while till it starts again .
Has anyone replaced these switches , [there are two in total ] ?Are they a Honda part only ?
What is the replacement cost of them .
It is possible to hear them "clicking" in operation . Do they receive their instruction to open or close from the PGM box of tricks ?
Regards Mike
						- raveydavey
Re: A/R VACUUM SWITCHES
Hi Mike
You're delving deeper than I've dared (or had time) to go. So;
1. No I haven't replaced either of them.
2. Don't know about Honda only part - If they're made by Denso, perhaps they're available elsewhere (couldn't read the numbers on the photo so couldn't do an internet search).
3. If they "click" then persumably there's a servo/relay that operates the rod/diaphram? The LT wiring diagram shows 2 wires to each. One is a common from the kill switch (black/white I think), the other wire per vacuum switch does indeed come from the black (Pandora's) box of tricks.
I can't remember if they are both the same - if so, have you tried swapping them over? Isn't one directly connected to the idle/air screw?
Sorry I can't be of more help.
Cheers RD
Cheers RD
The numbers i think read --- 384600-3480 12v Denso .
Once i get the alternator back on and the bike running i will know more, but i don't think the switches /relays are the problem .
Regards Mike
