Power valve - how to clean?
Hi there all,
Ive just bought a CRM 250 Mk 2 to cure my mid life crisis - seems very heavy compared to my MX'ers of 25 years ago, maybe I'm just getting old.
I've got the exhasut off for a clean out with caustic soda and thought I'd also clean up the coked up power valve.
I've removed the cables and bolts and the valve is now loose but wont come our thru the exhaust port.
Is there a special way to extract the valve?
Chris from Down Under.
Re: Power valve - how to clean?
Unfortunately to get at the real carbonised bits does really require a full dis- assembly.
I'm guessing they weigh about 15 kg more than your average MXr , but look at all the extra bits its carting around , and that frame is pretty robust and built to last .
Regards Mike
I have done it but can remember which way it came out, i think it was through the barrel. it was a bit of a squeeze but this is mainly down to a carbon build up and will go back in a lot easier. Jon
A heat tolerant grease is a good idea on reassembly to all moving parts.
The upside is once thoroughly cleaned and working again you are rewarded with that silky smooth power delivery again , and good for another 20k .
Regards Mike
Remove the shaft through from the side and the valve will come out through the exhaust port. It will take a little juggling to get it in the right position but it will come out.
There is only one way it can go back together so replacing is easy.
Sorry for any disinformation Chris,i hope she's all back together and running sweetly again shortly.
Regards Mike
FMtB
I think the system is different on the AR compared to the others.
I will have to have a looksee, but from a cursory inspection i think your right, which is maybe why i decided to service all the top end at the same time.
