mk2 wiring help needed please
hello peeps
i need some help with my wiring
1 what wires on the loom connect to the headlight
2 what wires are what on the rear light connecting block
3 my bike has ceised to run it has no spark im going to see if the new kill switch is on is off and i need to clean the points on the flywheel but is ther anything else i should look at
everyones help no matter how little will help me infinatly and i thank you in advance
thanks
thanks
Re: mk2 wiring help needed please
Headlight wires are White, blue and green
Bypass the kill switch by unplugging it
not sure on the rear light but just remeber that earth is dark green
surely you need to connect the kill switch wires together!!!Jonorow wrote:Headlight wires are White, blue and green
I cant remember i think the kill switch works by making the connection not breaking it
all of your help is very usefull thank you
keep it coming please
Remove the big black cylinder under the headlight (capacitor). Connect a 9v PP3 battery across the terminals this was connected to (+ to red, -ve to green) and use this to test the wiring for the front and rear lights using the switches as you would normally. If you have a circuit tester use this, if not a 9/12v bulb will do.
is the black capicitator your talkin about attached to the headlight bracket
looks like a indicator relay ( thats what i thought it was )
Capacitor is tubular; relay is much smaller and square.
