Quick Question
Quick Question
Alright guys
Quick question,
Ive got a set of off road wheels now for my bike.
So im now going to be running 14/50 gearing
My sm wheels are 14/41 so im going to buy a new chain.
How many links will i need and whats the numbers i need to know, 520.... something
Quick question,
99 HONDA CRM250 AR MUGEN
KTM 525 EXC SUPERMOTO 05
- 2016NWAA
Re: Quick Question
I usually buy chain 120 links mainly because that is what the shop stocks.
I fit the new chain and sprockets, put the new chain on and pull it somewhere near the right tension with the wheel as far forward as possible. I then mark the chain where it needs cutting and cut approx 5 links off by grinding the rivet head and knocking the rivet out with a punch. Remember that if you cut it too long you get another go but if you cut it too short you will have 2 split links.
If you intend to ride off road make sure you buy an O ring chain.
Re: Quick Question
Noting, to cut to a inner section of chain, and not the outer links, doh.Eddie Evans wrote:I usually buy chain 120 links mainly because that is what the shop stocks.
Yes 520 chain and +1 for the O-ring endorsement.
Leisure Trail will sell you a kit, and work out the chain length required.
As your going to be switching the chain about quite often, get some extra spring links for when the originals tire.
Re: Quick Question
You'll need a chain block dropper with a 50 tooth rear if you've still got the rear lower chain guide fitted.
You could run 45 tooth on the rear on both sets of wheels and then use a 13 for off-road and a 15 for on-road on the front. Maybe you could have slightly different rears like a 44 for road, 46 for off-road coupled with the front changes. That way you won't need to mess about with the chain length when you change wheels, just swap sprockets.
Re: Quick Question
The same thought had crossed my mind, I run 14/45, Trail, Trials, General purpose.AlanH wrote:You'll need a chain block dropper with a 50 tooth rear if you've still got the rear lower chain guide fitted.
With the 15 tooth front, it be necessary to remove the case saver
Re: Quick Question
I've just got hold of a spare case saver to modify to allow a 15 tooth front to be fitted. Hopefully it won't need too much ground off it.
Re: Quick Question
Cheers for the info guys
All sorted now
All sorted now
