Steering Head Bearings?
xander77
Forum Regular
Forum Regular
Post by xander77 »
Anyone know if other models steering head bearings will fit? i.e XR CR?
Jack
Mudfacetony
Bike Owned: Mk2.2, Mk3
Re: Steering Head Bearings?
Post by Mudfacetony »
Try this place for head bearings. I know the Mk2 and Mk3 use the same bearing and I think all Mk1 to AR use the same bearing
The lower link takes you straight to the taper bearing they reccomended to me when I gave them the CRM taper bearing code
www.simplybearings.co.uk
http://simplybearings.co.uk/shop/p43714 ... _info.html
kostas
Post by kostas »
I changed mine last summer.I went to a local bearing shop with the old ones to find out that the top and bottom bearings aren't the same.The codes are 32005X/26(MBS) for the top and 4T-CR-0574(NTN) for bottom(the brands are what the shop had).I did some internet searcing and even if im not sure,the codes mean the same dimensions but i saw the bearings and they aren't the same.I can ensure you that these work for AR.
