Flickering temp light on AR
TwoStrokeJunky
Post by TwoStrokeJunky » 12 Aug 2010, 14:13
Wondering if anyone has experienced this. My temperature light flickers on and off on occassion, especially when riding on tar and hitting a bump. This is very intermittent.
Another question, does fitting booysen reeds increase fuel consumption?
cheers
wheelright
Bike Owned: crm mk2
Re: Flickering temp light on AR
Post by wheelright » 12 Aug 2010, 15:19
The light also doubles up as a low oil level reading . is that ok ?.if the oil is ok and the bike isnt hot check all the connections on the rad and oil tank etc,
AlanH
Forum Regular
Forum Regular
Post by AlanH » 12 Aug 2010, 16:22
[quote="wheelright"]The light also doubles up as a low oil level reading[/quote]
No it doesn't. The light marked TEMP is for temperature and the light marked OIL is for oil level. If it's the temp one flickering, chances are you've got a wiring issue perhaps with the sensor wire chafed through and shorting to earth somewhere when you hit a bump.
Post by knackeredMk1 » 12 Aug 2010, 17:50
AlanH +1.
wheelright
Bike Owned: crm mk2
Post by wheelright » 14 Aug 2010, 10:08
OOOOOOOOPS, Yes sorry, i stand corrected, wrong bike , :cry:
AlanH
Forum Regular
Forum Regular
Post by AlanH » 14 Aug 2010, 15:59
You did get me wondering. I had to look in the garage to check :)
TwoStrokeJunky
Post by TwoStrokeJunky » 19 Aug 2010, 10:30
Thanks chaps, i will have a look at the wiring.
My other question: does fitting Boyessen reeds make a big difference to the fuel consumption? I do a lot of adventure riding in South Africa and fuel/distance is challenging at times.
