powervalve problem
raz1966
powervalve problem
Post by raz1966 »
i dont think the powervalve works on my crm, when you take the cover off and rev the engine nothing happens, i tried to open it by moving it with a screwdriver, it moved but once i started the engine it closed and stayed closed, i am used to yamahas ypvs system so i dont know how the honda one works.
raz1966
Re: powervalve problem
Post by raz1966 »
i just found the bit on here about powervalves, i shall have a go tomorrow
SkidMark
Post by SkidMark »
this is the 'master' troubleshooting guide -
viewtopic.php?f=6&t=3010
work your way through it to narrow down whether it is your actual valve carboned up, a problem with the Servo unit or the ECU...
let us know what you find out.
