i need a mk 1 engine ??????? crankcase hole
nathan93crm250
Post by nathan93crm250 »
recently my sprocket came off and has put a hole in my crankcase .. so i am after a new engine ........................ or any ideas on how to fix ? there is a chunk out of it 2cm by 3cm
voodookid37
Bike Owned: mk1
Re: i need a mk 1 engine ??????? crankcase hole
Post by voodookid37 »
did the exact same thing here............ended up fitting a mk2.2
mine smashed up the gear change shaft area.
nathan93crm250
exactly the same thing happend to me, can i ask what else you had to do to put the mk 2 engine in ~? i can get a hold of a mk 2 engine but dont know what else i will have to change
Bike Owned: KTM 200 exc
Post by back off road »
its useful to try the search facility as most things have come up in the past
viewtopic.php?f=6&t=7232
voodookid37
Bike Owned: mk1
nathan93crm250 wrote:exactly the same thing happend to me, can i ask what else you had to do to put the mk 2 engine in ~? i can get a hold of a mk 2 engine but dont know what else i will have to change
pmd
