My CRM 250 MK2 - Condition at time of purchase
- F-A-B-I-O
- Bike Owned: CRM 250 MK2
Hi all,
Please find a link below to photo's of my CRM MK2 at time of purchase.
Will be adding further pictures over the coming weeks as I mod and prep the bike ready for off road use.
http://s1159.photobucket.com/albums/p63 ... purchased/
Cheers,
Mark
Cheers,
Mark
Re: My CRM 250 MK2 - Condition at time of purchase
tidy looking and unmolested looks like it was worth the trip
- F-A-B-I-O
General condition is excellent.
DEP pipe has no dents and little rusting, frame could do with a few touch ups. Sprockets, Renthal 13/46 are good as is the chain.
I knew from purchase that the dreaded swing arm bearings/bushes etc need changing.
Cold starting at the start of a day can take several to a dozen kicks, am going to investigate this on the weekend. However kicks up first time, every time thereafter even if the engine has gone cold during that day.
All in all am well pleased with the purchase, cant wait to get her prepped for off road use.
Check out the technique my son, it usually works.
"Cold starting at the start of a day can take several to a dozen kicks, am going to investigate this on the weekend. However kicks up first time, every time thereafter even if the engine has gone cold during that day."
Also a clean/ replacement of the pilot jet sounds in order.
Looks good though.
Looks good though.
- njhardy
- Forum Regular
- Bike Owned: CRM250 Mk3
Nice buy fabio- a clean bike that hasn't been messed about with. Probably needs a good clean out and general overhaul. Have you checked the compression??
- F-A-B-I-O
Cheers guys,
Now come's the fun bit, making it my own and fit for off road use.
- F-A-B-I-O
Hi all there doesnt seem to be enough hours in the day at the moment
Anyway I thought I would keep you updated on how its going: - Managed to spend a bit of time on the bike on sunday, have changed the oil, checked the filter, generally cleaned the bike. Have changed the hand grips and added bark busters. I have also removed the front sprocket cover and rear plastic chain guard.
Loads more to do including the dreaded swing arm bearings
http://s1159.photobucket.com/albums/p63 ... 20Project/
