Hello from oxfordshire
biofotis
Post by biofotis »
Hello
I am an old member here watching the forum for long time and some days ago I bought my self a crm250ar project for fun.
I was in between this and a yamaha wr200. (both need work)
I bought it for 400GBP but as I said it needs some work.
First it needs a crank rebuild since the big end is dead...After some research I found that you dont have many options here as honda sells the whole crank...But mine has a wiseco rod but I cant find it anywhere online.
and secondly, the previous owner put steel liner in the cylinder and now I need to rebore it and install a new piston. However finding a suitable piston is hard!
Also its missing the headlight and chain cover.
At least forks are straight with no damage, it has the license plate holder with tail lights, no rust in tank very good speedometer etc.
So the question, does it worth fixing it? or sell the parts individually and buy something else like the wr200? I wasnt aware that it was that hard to find parts for this bike! ebay is empty!
Re: Hello from oxfordshire
As Spock might have said, " the needs of the many outweighs the needs of the one", or something like that, break it. ;)
As a direct comparison the WR and a CRM do not equate, the first being a competitive Enduro bike, the latter being an awesome Trail bike, horses for courses.
If your bike has a Wiseco conrod and an iron sleeve someone has done some extensive work on the engine and I don't know where you would look for replacement parts. FMtB is correct with his advice but you are going to have some difficulty with the engine and electrics proving nothing else has been altered.
If you can give some links to photos of the bike and the items under discussion this might help?
biofotis
Post by biofotis »
I would like to keep it for a while and see if I can source the parts needed. However, I cannot find anything! Where do you people look for second hand parts? ebay has nothing
If you can list what you need then there are some on here that have parts. eBay is a good source but AR bits are rarer.
You engine (If it is an AR) has had some heavy work done so unless you can accurately measure things like the conrod then you are going to have trouble finding them. With the conrod and iron barrel I suspect you have a different piston from the usual (CRM/TRX 87-89) as well. And you may find your cylinder is not the original height.
Photos of the bike and engine parts would help confirm even if it were an AR. We regularly get mislead by owners who claim their bike is an X when it turns out to be a Y.
biofotis
Post by biofotis »
I have taken apart the engine today and its definitely an AR model.
Here is the bike when I got it
http://imageshack.us/a/img703/918/8wk8.jpg
The piston (wiseco)
http://imageshack.us/a/img841/2060/niq6.jpg
The cylinder
http://imageshack.us/a/img822/7550/23pq.jpg
The reed block. It looks like someone have played with it a bit
http://imageshack.us/a/img541/8875/xv1s.jpg
and finally the conrod. Its a wiseco one.
http://imageshack.us/a/img710/2328/fw6n.jpg
This rod is quite famous in Greece but they say the big end bearing doesnt last for long. I dont know why though...Any other alternatives for a conrod?
You have a Mk3 not an AR.
There is no Wiseco conrod that fits directly on a CRM. I suspect (looks like) that the piston has a higher crown than the standard piston.
I suspect that you have a slightly shorter than standard conrod and a slightly taller than standard piston and the barrel has been skimmed to bring the piston up to the correct port height.
biofotis
Post by biofotis »
conrod is 13cm center to center
the cylinder is 10.9cm high
piston is 7.45 high, 66mm width with domed crone. Small end center to piston end is 3.4cm
What do you mean by mk3? Everything says AR on them! It has the solenoids, the strange carb, the multiple pickups etc
biofotis
Post by biofotis »
i meant crown...
I can't see the PV cover from the photo of the whole bike and the cylinder looks like a Mk3 from the inside. If it has solenoids then AR.
Original conrod (centre to centre) - 132.5mm
Total piston length (crown to skirt) - ~80mm
Centre of small end to top of crown vertically ~32.5mm
Piston width can be anything from 66.0mm - 68.25mm. Original AR was 66.4mm and 'Nicosil' type lined. Others were iron sleeved.
biofotis
Post by biofotis »
yeah its the big valve type with AR on the cover.
I took some more measurements today, center to center measured at 132.6mm so I guess this makes it 132.5mm
small end width 17mm
small end diameter 22mm
big end width 17mm (plus 1mm each washer)
I cannot measure the diameter of the big end is its currently on the crank and I need to press it out. the pin however is 25mm.
Now for the piston
pin diameter is 18mm
piston bore 66mm
if i put the piston upside down it measures 80mm from the center of the crown until the end of the skirt
I spoke with a Greek engineer down there and they said its a common practice to install a wiseco conrod but it doesnt last as the original crank.
Ok from those measurments it looks like standard sizes but with an iron liner rather than the chromed one. I would like to know what bike the Wiseco conrod comes from as I, and others, haven't managed to find out. Would be of considerable benefit to the forum to know.
As the iron bore is reborable pistons should be easy to find.
What parts are you actually looking for?
biofotis
Post by biofotis »
yeah I saw that LT is rebuilding the cranks but you dont know what conrods they are using and they dont tell as well.
I always distribute information regarding two strokes and I am happy to share this as well!
I also found how to change the power valve timings on yamahas (YPVS) and posted it on the forums.
The rod has printed a part number: WR10019
I dont know how to search their catalog though...
regarding the parts, I need the rear chain guide (the white one), headlight (i know its rare but maybe an aftermarket that looks like it?), sprocket cover and oil tank(mine has one lug broken)
obviously a crank would be nice but considering how rare they are I think it would be better to rebuild mine with a wiseco rod again. I have the knowledge how to do it myself and balance it properly but here in UK i dont have a press. I successfully rebuilt 2 rgv250 cranks and balanced them within specs.
