sprockets
Hunterm8
sprockets
Post by Hunterm8 »
hi
i need to get some new sprockets for my crm250 mk3 all the places ive looked online dont have crm250 What do i go for?
cheers mick
rogercrm
Post by rogercrm »
Hi Mick,
Depends what you're using the bike for.
Road riding and a bit of trail: 13/42
Lots of trail: 13/45
Serious trail/enduros: 13/50
Leisure trail do sprockets and an o ring chain set for £70ish, if you go larger than 45 teeth on the rear, you need a dropper block (from LT) at £27 - or make your own.
Hope this helps,
Roger.
Hunterm8
Post by Hunterm8 »
thanks that help on tooth size if i was to order one from here
http://www.racespec.co.uk/Shop%20Final/ ... lang=en-gb
what bike type would i choose as they do not list crm?
phil1
Post by phil1 »
Honda Xr400 should be the same, also brake discs, pads and wheels
Phil Neal
Post by Phil Neal »
bandc express are good too...
CRMR
Post by CRMR »
And dont forget :bigger sprockets = bigger chain :wink: and if you go for a 47 tooth rear youll get away with dropping (filing downwards)the original holes and lowering the original chain guide..just :wink:
MarkM
Post by MarkM »
I run mine on 13/48 with DEP and reeds and find it excellent and you can still use 1st gear !!!! Leisure Trail are good but can be pricey try race spece http://www.racespec.co.uk very competitive and cheaper when you order on-line.
XR 400 sprockets will fit
