CR/CRM Fork leg length
- Gettingfaster
- Bike Owned: CRM250 Mk2
I have (i think.....), 1991 CR 250 usd fronk forks in my mk 2. The front end seems high and i'm wondering if the CR forks are longer than the originals and so the geometry has been changed (steering is slow). I measure 920mm from the top of the fork leg to spindle (sat under it's own weight) and 945mm suspended wheels up on a stand. The springs are well past their sell by date and will be changing them soon, this may make things even worse. Anyone know what a Mk2 CRM fork leg measures? Also, can anyone tell me the correct measurement from yolk to spindle? I don't think the forks will drop more than 10mm through the yolks........any advise would be great.
- oilinsmoke
- Bike Owned: crm 250/2
Re: CR/CRM Fork leg length
Hi i have a mk2 can measure the legs for you if you like,i'm not a hundred percent certain on this but i thought the cr forks where larger diameter than crm could be wrong though
if you want me to measure them just msg me back and i'll go do it
rgeards
G
rgeards
G
- Gettingfaster
If you get chance to measure them that would be great, i'll have a better idea then. It steers better now i've dropped them through the yolks.
The CR forks are slightly smaller diameter (near the top). I've made spacers for the top clamps which are working well (been in 2 years).
A measurement would be great, thanks.
- pudzie83
- Bike Owned: mk2 1992
standard crm forks are shite always worh upgraging to cr/xr/ktm.A spacer/cover is required for good finish
- Gettingfaster
I've not tried standard forks as the CR forks were already on, but i have heard they are not great. The CR forks are pretty firm (which seems to be a general opinion) and i have them as soft as i can get them. No quick fix for that, just wondering how much they are affecting the steering.
- pudzie83
I tried my standard forks yesterday to see if i could use them at weston instead of potentially wrecking the cr seals i got on......they were removed just as fast as put on it lost its character completely, the frontend felt like a pogo stick looks like they're staying as the MOT/loan set
il measure them tomorrow for you as ive got a date down the mancave
- pudzie83
the cr ones i got (89/90 CR 250) are 60 cm the standard crm are 57 cm this was measured from the top to the seals
The cast aluminium legs are also longer. So the entire length is noticeably longer. You have to raise the CR forks through the yokes otherwise you get the 'riding a chopper' effect.
- pudzie83
Thats what ive had to do mine but well worth it when set up correct....every little helps
- Gettingfaster
Thanks all,
I've got them dropped through the yolks as far as possible now. Steers much better so i'll have to be happy with that.
Raced at the weekend and they were much inmproved, but they are on the hard side which i think has been posted on here before.
