crank seals
crank seals
Has anyone on here cross referenced their crank seals and bought non honda items.I contacted my local bearing shop and their seals are £30 cheaper for a pair than honda.has anyone used aftermarket seals ?
Re: crank seals
Loads.
Re: crank seals
You can get the "viton" seals for less than the the cost of standard Honda seals.
They will out perform most any other seal.
Re: crank seals
£30 cheaper for the seals ?warloks wrote:Has anyone on here cross referenced their crank seals and bought non honda items.I contacted my local bearing shop and their seals are £30 cheaper for a pair than honda.has anyone used aftermarket seals ?
91202-KAE-004 main bearing oil seal clutch side £21.80
91203-KAE-003 main bearing oil seal generator side £ 7.70
91354-KAE-000 o-ring for crank clutch side £ 1.73
or am i being a numpty again ?
Re: crank seals
I got a price from fowlersjompy wrote:£30 cheaper for the seals ?warloks wrote:Has anyone on here cross referenced their crank seals and bought non honda items.I contacted my local bearing shop and their seals are £30 cheaper for a pair than honda.has anyone used aftermarket seals ?
91202-KAE-004 main bearing oil seal clutch side £17.84 +vat
91203-KAE-003 main bearing oil seal generator side £17.84 +vat
my local bearing shop can do the pair for £10
where did you get your prices from ??
Re: crank seals
Mine were from Leisure Trail Inc VAT so O.E.M
I used to shop around especially with bearings but to be fair I thought the O.E.M prices weren't too bad
- Speeddevice
- Bike Owned: Mk 2
Re: crank seals
Here's a reference that I use to look up the TC equivalent oil seal;
http://www.bsc.com.au/sites/default/fil ... 0Seals.pdf
all you need to do is measure the shaft diameter or seal ID, the housing diameter or seal OD and the thickness.
The TC part number is then commonly available and much cheaper than the Honda part.
Re: crank seals
Cheers for that bud
