input shaft bearing
pudzie83
Bike Owned: mk2 1992
input shaft bearing
Post by pudzie83 »
Hi all im trying to source a input shaft bearing for my mk2 (the one with seals located behind the clutch basket) leisure trail have none left has anyone got any information on where else might have them?
or has anyone got one kicking around they never used??
thanks
Re: input shaft bearing
Have you tried a bearing factor outlet?
jompy
Forum Ghost
Forum Ghost
Bike Owned: MK2
Post by jompy »
+1 Mike
Take the bearing to a bearing suppliers
pudzie83
Post by pudzie83 »
Im going to pop to the local bearing place monday if i get no luck on here got every other one but that :(
jompy
Forum Ghost
Forum Ghost
Bike Owned: MK2
Post by jompy »
I'm sure if they don't have it they'll order it
pudzie83
Post by pudzie83 »
discontinued jompy il get one made if need be
jompy
Forum Ghost
Forum Ghost
Bike Owned: MK2
Post by jompy »
sorry bud i meant if the bearing factors don't have it they'll order it in for you
On the parts diagram it is very difficult to be sure what bearing goes where but if you can give me the outside diameter and perhaps the inside as well then I can work out which one it is. It is very likely that it is a standard size anyway.
pudzie83
Post by pudzie83 »
The measurements are 56 outside 24 inside and 15 whith bearing number is sco5a86 and the seal on one side has the same code but ending in lu
My mechanics doing some digging around so hopefully we get somewhere and a search on google has brought some leads up to chase
pudzie83
Post by pudzie83 »
well people it looks like ive sourced the "obsolete" bearing! defeat is just a word :lol: i will be ordering and if all is good i will post the link as it may help others
Yes but it's 24x56x14.
Honda part no, 91001-ML3-873 Not sure why there is a CRM part no for this? Perhaps there is a different number if bearing seals or none?
Suzuki p.n. 09262-24001
~£11.
pudzie83
Post by pudzie83 »
would one of those 91001-ML3-873 bearings be ok? il be honest im not very clued up when it comes to bottom ends
According to all the sizes this will be fine.
pudzie83
Post by pudzie83 »
thanks knackered :BB do you know if it will have a seal? the original bearing has a seal on one side is this important?
If the bearing comes with two seals then take the one off that isn't on the original. If there are none don't worry.
