rear shock spring
NaBz
rear shock spring
Post by NaBz »
are the rear shock springs powdercoated from factory?? or some other painting method??
Thought i would ask before i send mine off to powder coat to only find it cracks away or sumin.
and while on the shock subject the rubber bung bit on the shock where can i find a new one ??
rear shock bump stop...
nick
NaBz
Re: rear shock spring
Post by NaBz »
ok ill ask him when he is online,
maybe ill go upto the powder coat place and ask them, they may have some special stuff for springs.
Anyone else powdercoated one before?.
nick
kernow krusty
Post by kernow krusty »
this is gonna sound like anuvver ad..but as Ive got the catalogue, may as well share it!
Off Road Only do rear shock service parts including the bump stop for the CR's and XR's. If you can cross ref the shaft size, Im sure thats the main consideration. They are about £15-£17.
NaBz
Post by NaBz »
ok cheers m8 will check that out
nick
andypugh
Post by andypugh »
kernow krusty wrote:Off Road Only do rear shock service parts including the bump stop for the CR's and XR's. If you can cross ref the shaft size, Im sure thats the main consideration. They are about £15-£17.
If you look at the article I wrote about my DIY shock rebuild
viewtopic.php?f=6&t=3303
There is a link to the right page of the ORO online catalogue
http://www.oro2u.com/acatalog/250cc_HON ... _KITS.html
And the part number (for the seal head kit) is given as 29-661.A which is for the CR250 1998-1990 model.
So, by a process of guesswork and handwaving I reckon you want part number 29-231 from
http://www.oro2u.com/acatalog/copy_of_c ... HONDA.html
HTH
NaBz
Post by NaBz »
thanks alot m8
cheers for taking the time to have a search :D
nick
